Title Update 4 also fixes a number of lesser-known exploits.
• A player could copy game progression data from one profile to another.
• A team could use the 50-point revive bonus to artificially increase
its score in Horde. Going down but not out (DBNO) in Horde now
subtracts 50 points, so there is no advantage to using the revive-bonus
technique.
• A player could get 2 points for each kill in Wingman.
• A player could continue to shoot the Flamethrower while performing special movements like evading and mantling.
• A player could cause heavy weapons to spawn continuously while playing Horde.
• An issue that could cause players to lose all achievement progression if they signed in during a loading screen.
• Issues related to the Smoke Grenade causing a player to cringe
instead of knocking them down. If hit by a Smoke Grenade with cringing
turned on, players will now:
o Drop the Boomshield, even if aiming while carrying it.
o Drop a heavy weapon, even if it is deployed.
o Cringe while roadie running.
o Cringe while in cover.
Balancing
• An issue that prevented players from shooting around the lower left side of a planted shield.
• An issue that could cause a DBNO player to not appear as DBNO.
• An issue that prevented Gears players from inviting players of other
games to join them in progress in a Private match using DLC.
• Issues that caused rich presence information to become inaccurate.
• An issue that caused the overall achievements progress bar to not reflect the latest achievements.
• An assortment of localization bug fixes.
• Additional miscellaneous bug fixes.
• Adds a 30-second delay in map-based weapon spawning at the beginning of a Wingman match.
• Adds more future server-side balancing options.
. So schwer ist das wirklich nicht, les dir einfach die entsprechenden Threads hier im Forum durch und du wirst es hinbekommen. Stell dann bitte auch die Fragen einfach in diese Threads rein. Ohne VPN wirst du nie an diese Maps rankommen, ausser du machst mal Urlaub in Österreich oder der Schweiz nimmst deine Box mit und lädst die INhalte dort runter Besitzt du ein Laptop? Dann brauchst du eigentlich gar nix von den beiden!ich besitze aber keinen "router" und keine 2 netzwerkkarten. und nur wegen EINEM spiel. das alles zu besorgen und einzurichten seh ich nicht ein
Gears 2 Double XP Weekend Brings a Flood of Tickers
Gears of War 2 celebrates the Fourth of July holiday with an explosive Double XP Weekend! Starting Friday, July 3, and running through the weekend, Gearheads can expect double XP in all game types, as well as bonus XP for those teams emerging victorious from battle. And if you’re in the mood for fireworks, be sure to check out the special all-Ticker rounds in every tenth wave of Horde!
5 Besucher
