...Riegel meine ich...
Original von kkk-Didi
Wie findet ihr meine neue Signatur?
Original von LOKI l
In dem ich nach deinem Posting-Text einfach immer weiter lese - wie denn sonst?![]()
Original von LOKI l
Rot oder Blau?
Beide!
Original von LOKI l
Amicus certus in re incerta cernitur! "Den wahren Freund erkennt man in unsicherer Lage!"
Sehr philosophisch - gefällt mir!![]()
Wer auch immer das übersetzt hat, hält wohl nicht viel vom einfachen Wort!
As appreciation to our friends from dlash.de, we are distributing keys to a number of people from the forums. Please do not post about this on the forums as we don’t want anyone who didn’t get a key to feel left out. We will be sending out more keys soon!
If you already have a key, please forward this email to a friend. Thanks!
WELCOME TO THE FRONTLINES: FUEL OF WAR BETA!
We are doing everything we can to make Frontlines: Fuel of War the best game possible and your participation will help get us there!
The best place to get information about beta and get help if you are having technical problems is our beta forums:
http://community.kaosstudios.com
The credentials for this area are:
Username: FETT
Password: Liebe
Note that you do need the exclamation point at the end of the password.
After the initial password challenge, you will also have to register an account and use first the security login and your personal login in the future.
BETA CONTACTS
If you are having problems with the beta, please post on the forums (after checking to see if there is information on your issue posted already). You will get the fastest response from people who are also having similar problems and may have already solved them. With the volume of posts it can take time to spot every issue.
If you are not getting the problem resolved please use the contacts listed below:
* Fileplanet registration/login fails -> http://support.fileplanet.com
* Key not received or lost -> http://support.fileplanet.com
* Key not working -> accountsupport@kaosstudios.com
* Other game account issues -> accountsupport@kaosstudios.com
* Can't get past the security login for beta forums -> forumsupport@kaosstudios.com
* Can't register for beta forums -> forumsupport@kaosstudios.com
* Can't patch/install -> post on beta forums
* Bugs/feedback -> post on beta forums
If you lose the key from Fileplanet, login and it should be on this page:
http://www.fileplanet.com/betas/keydisplay_test.aspx
Please do NOT email or PM us bugs or feedback on the game, that is what the forums are for.
GAME DOWNLOADS
Your beta key is listed below:
xxxxx-xxxxx-xxxxx-xxxxx-xxxxx
The 0.2.1 installer is hosted by Fileplanet at the link below:
http://www.fileplanet.com/179491/170000/…es:-Fuel-of-War
We also have it hosted at the following link though it may be a slower download:
http://patchsvr2.frontlinesgame.com/patc…W_Setup_021.exe
Patches can usually be found at this link:
http://www.kaosstudios.com/ffow-patches/
Note, we did just release a small patch (0.2.2) that you will also need to install.
KNOWN ISSUES
* System Spec - AMD Single Core Processors causing issues/unstable and being investigated (No issues with Dual Core AMD Processors).
* Graphics Card - Shader 2.0 graphic cards currently unstable
* Patches from 0.1.# releases are unstable. Please uninstall FFOW and download the 0.2.0 installer and then use the 0.2.1 patch, then the 0.2.2 patch.
* Uninstalling FFOW – depending upon how many patches you have gone through you may need to manually uninstall FFOW. See the forums for instructions.
* Registry Key/Accounts problems – If you receive any problems with your Registry Key please e-mail AccountSupport@kaosstudios.com immediately. Please include your registry key number in the email.
* Deploying: If all of your teams objective points/launch points have been taken over or gone to the neutral state you may no longer be able to deploy until the round is completely over.
FIXED BUGS:
* Server Memory Leak - In our testing we found that we had a memory leak that would eventually lead to unstable servers and stopping the ability to deploy and launch into games – this should be fixed.
* Server Browser - The server browser will now time out after a period of time so that users no longer have to quit the game when it is stuck in a loop.
* Frontline - A fix has been put in that will fix both the frontline from showing to many objectives and frontline objectives disappearing – this will also fix another deploying issue.
* Logs - documentation has been added to log files for troubleshooting purposes
* UI Popup - New popups have been added to specify the reasons for failed account creations and logins.
WHAT CAN YOU NOT DO WHILE BEING A PARTICIPANT IN THIS BETA TEST?
We are excited to have you involved in this test but the version you will be playing does not reflect the final game. Certain visual and functional attributes are either placeholder content or modifications that are implemented to gather needed data. Because of this, we require you to abide by the following rules:
* No posting of any information about the beta to anyone outside of the beta forums. This includes telling people you are participating in the beta.
* Posting of screenshots, audio, video, logs or other files may only be hosted on private accounts or servers and linked to in the beta forums.
* We are allowing people to use voice chat servers but you must password protect the channels and only allow in other beta players!
* No reverse engineering, adjusting or modifying the code of the game - note that modifying config files could make the beta unplayable!
* No sharing of CD Security Keys with other people. However, the game may be installed on multiple PCs for your personal use.
More detail is listed in the NDA (non-disclosure agreement) and EULA (end-user license agreement) you must agree to before participating in this test.
WHAT IS AVAILABLE IN THIS FIRST BETA?
The initial release will contain early versions of two multiplayer maps:
· Mountaintop - Red Star and Coalition forces battle over a mountaintop that guards a strategic pass below.
· Gnaw – Coalition forces attempt to do what Napoleon and Hitler could not; beat the Russians in the streets of Moscow.
WHAT IS NOT CONTAINED IN THIS FIRST BETA?
This early version beta contains only a small portion of what will be released in the final game.
Not included:
· Leaderboards
· In-game – “Quickcom” communication system
· Air Vehicles (except for drones)
· VOIP (you may use TeamSpeak or any other third party Voice-over-IP program).
· Medals/awards/achievements
· Key binding (will be added in a future beta patch)
Not functioning or disabled:
· Portions of the user interface
Full information on the game (including information on the Frontline mechanic, roles, loadouts and more can be found in the manual located in your game directory.
HARDWARE REQUIREMENTS
Minimum to Play*
* Windows(R) XP\Vista
* DirectR) 9.0c
* 2.5 GHz Pentium IV or equivalent AMD Athlon XP processor**
* 1 GB RAM
* 3 GB free hard drive space for installation
* Graphics Cards**
o NVidia Geforce 6 or higher w/256MB
o ATI Radeon X1K Series or higher w/256MB
* DirectR) 9.0c compatible 16-bit sound card
* Broadband Internet connection.
* Minimum specifications are in progress, the requirements will get lower over the course of beta.
Recommended to Play
* DirectR) 9.0c
* 3.4 GHz Pentium IV or equivalent AMD Athlon XP processor**
* 1.5 GB RAM
* Graphics Cards**
o NVidia Geforce 7800 GTX or higher
o ATI Radeon X19xx Series or higher
** Current known hardware issues:
THANK YOU!
We would like to thank everyone for supporting Kaos Studios and are excited that you will get a chance to play Frontlines. Your help will make Frontlines: Fuel of War the best game possible!
Thanks,
Your friends at Kaos Studios
Original von das flo
scheiß newton'sche axiome...
nabend ladies
und .... was gibts so neues in der ingolstadter richtung?![]()
nächste woche ferien
in physik steh ich zurzeit auf 3,5punkten (also note: 4,5)
und sonst is auch alles cool, bis auf den scheiß laser meines 360-laufwerks
11 Besucher
