Original von ALFistA
Original von Sesing
Wann bestellst Du das denn?
ich werde wohl ersteinmal etwas mit den original spielen und schauen wie weit ich damit spielen kann glaub kaum das man in den ersten schwierigkeitsstufen sofort das neue pedal braucht.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »TheOneWG« (7. Mai 2008, 21:05)
QM vs EL
I'm adding this section in first to try to explain things.
Both sets have some advantages and disadvantages. Your play still will determine which works better for you. Also each set has a different tendency, and just because you have one or the other doesn’t mean it’s exactly like this
QM
The QM is generally extremely sensitive. Even the smallest tap will set it off. The rebound on the pads seem to stay more consistent through play. They seem to break less, and the blue and yellow pads don’t appear to crack as easily as on the EL. The QM on fast rolls generally does poorly. Because the sensors are so sensitive, as the force of your hit increases, the sensors cease to register, or will register double and triple hits (due to lack of sensor damping). Sskitzzo has confirmed the drums in his video “broken drum pad”, were the QM model because they exhibits all of these tendencies.
EL
The EL isn’t nearly as sensitive. It takes more of an actual hit to set it off. The available travel on the pads is greater and seems to deteriorate through play. The yellow and blue pads seem especially prone to cracking and denting, while I suspect the red and green pads still live longer than the QM versions. Fast rolls are a lot easier on the EL, because the sensor is damped. Unfortunately this also means that you’re hitting it harder, generally leading to dented heads. It also has a tendency to occasionally not register a hit, making FCs sometimes difficult on this model.
Original von dunes
Heir mal eine kleine Übersicht über die wichtigsten 3rd Party Rock Band Addons
Drums:
Drum Pads - http://drumpads4rockband.com
RocPadz - http://www.rocpadz.com/
Support Struts - http://www.goodwoodmods.com/products.html
Bass Pedal:
Destroyer Pedal - http://rockbandpedal.net/
Omega Pedal - http://omegapedal.com/
Rock Pedal - http://www.rockpedal.com/
Original von Smasher
Von einem CH Shop:
Rockband wird nur für Xbox 360 am 23. Mai released. Und vor allem nur in einigen Ländern wie Deutschland, England, Frankreich und Italien. Gemäss Lieferanten werden Downloads von der Schweiz mit der deutschen Version nicht funktionieren (ähnlich wie beim Call of Duty 4-Map Pack), weshalb wir die deutsche Version bisher nicht gelistet haben.
Man man man, ich kapier echt nicht warum EA son Theater mit dem Spiel macht.Denkt ihr die DLC würden funktionieren wenn ich ein D Account machen würde und dort die Daten downloade? Ich denke mal falls es eh nicht in CH rauskomt werden die wohl auch nichts im CH Makrtplatz anbieten.
Original von Bens1984
hallo!
hat jemand zufällig schonmal bei media markt gefragt, was das spiel und was die instrumenten-box kosten soll?
vllt haben die ja ein angebot zum release stehen...
Original von Sesing
199,- hört sich gut an, damit habe ich auch schon gerechnet.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »xGamer« (10. Mai 2008, 03:20)
Original von xGamer
Also ich find den Sound von GH3 ürgend wie, viel viel besser!
Beispiel: KLICK Black Sabbath - Paranoid hört sich in GH3 tausend ma besser an!
In GH3 ist es einer meiner Lieblings Tracks von daher fällt mirdas sehr auf, hört sich längst nicht so gut an wie in GH3 , auch wenn die Olle nicht mit singen würde wäre es nicht besser
Wie dieser Clip beweist!
ausserdem sind die lieder von rockband zerstückelt weil es mehrere tonspuren sind während bei gh3 das lied aus einem guss besteht. bei rockband gibt es ja drums, lead gitarre, bass und gesang die einzeln sind. das system dahin ist nicht ganz vergleichbar deswegen hören sich die lieder etwas komisch an anfangs. wenn man gh3 im coop spielt ist der spieler der bass spielt total im nachteil weil man den bass kaum hört das kommt daher weil der bass nicht einzeln ist sonder schon mit den mastertrack verschmolzen ist das ist bei rockband besser gelösst, die instrumente sind sehr deutlich zu hören
und ja die rockband version ist mies ka warum die diesen müll da rein machen es gibt noch andere covers in rockband Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »ALFistA« (10. Mai 2008, 03:35)
