quelle?waffen die bestätigt sind durch die trailer/scans:
Steyr AUG![]()
UMP .45![]()
FAMAS
ein AK modell
Glock 17![]()
M16-artiges Gewehr mit ACOG und Launchernoobs incoming!
Soap is in the game as a "grizzled vet" NPC.
Single player enemies will have "customized" weapons similar to the multiplayer component of COD4.
The ice mission shown to GI demonstrated the game's open-ended approach to combat, showing how stealth can be implemented if the player chooses.
While the gameplay is open-ended, the story is "on-rails".
Infinity Ward realizes that the "invisible line" where enemies will stop coming in COD4 wasn't great, so they're trying hard to eliminate that. Also, they are lengthening the single player past the 6-10 hour mark of COD4.
"Special Forces Mode" is a major part of MW2, a series of missions in the spirit of the Mile High Club from COD4. It will also have co-op in this mode. Gears-style bleed-out-and-partner-revive will be used.
Co-op apparently won't exist in Story Mode.
Riot shields will be implemented in the game.
Zakhaev's former associate, Makarov, is the "new face of global terrorism."
Snowmobiles are used as a form of escape in the demonstration. Unclear whether or not the player will drive, shoot, or both.
Players will alternate using the two triggers to climb ice-walls.
Movable turrets will be used in SF mode and Single Player, no official word on online use.
IW wants to implement an accomplishment system to online, as they want to make their players famous.
Online mode will use a "Live-Patching" system, where IW can manipulate spawn logic or certain parts of a multiplayer map without doing a full-blown patch.
Another demoed area shows an enormous desert setting where Task Force 141 drops into a wasteland and must navigate a "lengthy trek" to a fully-rendered valley with scattered caves, reminiscent of Iron Man.
IW is focusing on details for the COD4 sequel, citing iced-up tire treads in the Russian level.
The game will run in 60fps (duh).
Steyr AUG![]()
UMP .45![]()
FAMAS
ein AK modell
Glock 17![]()
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Bratti« (12. Mai 2009, 20:26)
Wie sind die ganzen Jahre an dir vorbeigegangen?!Die hat doch nen Grantwerfer drann.
Acog mit GW? Hoffentlich nicht online, war ja bei CoD4 auch so: Im SP mehrere Aufsätze, online nur einer.
Is besser mit einem.
Ich kenn nur das Gefühl von CoD4.
Hab sonst noch kein CoD gespielt.
Auf jedenfall sieht sie geil aus.
Äh... und?Normalerweise is der Granatwerfer schon ein Perk.
Dann noch ein Perk für Acog, bleibt noch ein Perk. Mit dem ACOG für den GW zielen`?
Währe nicht so sinvoll.
Ausserdem unfair wenn man Schalldämpfer mit Rotpunkt nimmt.
Ich kann mir keine 2 Aufsätze vorstellen.
@ Veido
Es gb in CoD4 auch schon 2 Aufsätze aber nicht online.![]()
das es keine m16 ist sondern ne m4Äh..und?
Wie sind die ganzen Jahre an dir vorbeigegangen?!![]()
Modernisierte M16? Meinst du vielleicht M4A1?Auf jedenfall sieht sie geil aus.
Was hast du dann damit gemein???![]()
