Original von Starfish
Hallo Freunde,
ich hab's mittlerweile auch, bin noch nicht sehr weit, macht aber schon eine Menge Spaß. Was mich nur verwundert hat: war nicht immer die Rede von einer Installation wenn das Spiel das erste mal einlegt? Bei mir war da trotz Festplatte keine Spur von, handelt es sich da um einen Irrtum meinerseits?
Noch eine Frage: Kann man die Kamera im Fahrzeug irgendwie fixieren oder per Tastendruck wieder hinter das Fahrzeug springen lassen? Ich hab immernoch so meine Problemchen da ich die Kamera ständig mit manuell fixieren muss.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Fab1« (29. April 2008, 18:33)
Original von COol 360 GAMEr
PS3 Version hat geringere Auflösung
GTA IV Runs At 630P on PlayStation 3, So What's That Mean?
Early test reports are finding that Grand Theft Auto IV is only running at 630P on the PlayStation 3—falling short of hi def—while the game runs at 720P on the Xbox 360. Clearly, the PlayStation version must look worse, right? It's not that simple. But the basic explanation is easy enough to understand.
You know 720P (along with 1080P) as "high definition" content. What 720P really means is that 720 lines of resolution are displayed on your television in "progressive" format—meaning all at once.
So if GTA IV is running at only 630P on the PS3, that does mean PS3 gamers are seeing 90 less lines of resolution—or quite a bit from a relative standpoint. And it's fast-approaching the Wii's standard def, 480p output.
The bottom line is that resolution does matter, but the more lines of resolution you add will depreciate in value. There's an interesting stat that always sticks in my head: From only about 10 feet away, most people cannot tell a 720p image from a 1080p image on a 42" television.
I'm not sure how well I could differentiate a 630P signal from a 720P signal from 10 feet away. But I'm sure that, given large enough televisions and sharp enough eyes, some of us could. Especially in a game context.
But what we'd be overlooking is that eyes-on reports show that Rockstar has taken the processing power formerly spent on resolution and added it to filters (and maybe even lighting). If GTA IV feels warmer or softer on PS3, that's probably why. And that's where taste triumphs numbers.
(If you're having a tough time wrapping your head around the filter concept, mess with the settings in Mass Effect.)
At the end of the day, both versions look good. But the PS3 used methods other than raw resolution to get there. Of course sharpness and detail is an important—that will be the biggest bonus of 720P. But in an era when we're past merely counting polygons on the screen to measure graphical quality, we shouldn't blow small numbers out of proportion. In short, it's not just the size of your P, but how you use it that matters.
http://kotaku.com/385237/gta-iv-runs-at-…whats-that-mean
Abstürze und geringere Auflösung o.O Die PS3 ist echt 400€ wert![]()
Original von Marius92
Jap aber dezent schenellere ladezeiten und besseres aa soll sie auch haben....nur mal weil immer nur das schlechte genannt wird.
Original von Dusel
@all, kann mir jemand bei mienem problem helfen?
