The resolution of televisions and monitors is constantly rising. Currently NHK and a consortium of electronics companies are developing Ultra High Definition, a format with four to eight times the resolution of current HD television.
And the next PlayStation is rumored to be part of Sony's larger push.
If true this would hardly be surprising. Sony has often used the PlayStation to push other technologies at the same time. The success of the PlayStation 2 helped promote DVD as the next change in media. And the PlayStation 3 was built around the Blu-Ray drive as part of an attempt to win a format war… an effort that largely succeeded.
As for 4K, Sony is introducing an 80-inch set that supports the format and supposedly will be using the PS4 to promote it as part of a set.
Our Take: It seems likely that this is true: Sony would obviously like to sell more television sets.
It also seems likely that 4K will simply be an option available, especially since honestly it's unlikely the format will go very far for decades. It will make for some gorgeous booth displays and even better eSports.
But beyond that we're not really sure if this is for gamers. Sony certainly sees the PlayStation as a "living-room box" with far more than just games available for it. Still, we find it unlikely in an era of Netflix streaming and tight budgets that 4K games in of themselves will get any traction: Sony's flagship 4K set will cost a cool $30,000.
That said, we can't wait to see those tech demos.
Do you want 4K games? Or do you think Sony is asking a little much from your wallet?
kann es mir sehr schwer vorstellen ehrlich gesagt. so einen sprung wie damals zwischen xbox/xbox 360 oder ps2/ps3 erwarte ich nicht. 4k können wir erstmal eh vergessen. wird paar jahre brauchen und wird viel zu teuer sein. spiele mit solch hoher auflösung schaffen nicht mal monster rechner in naher zukunft. wird also bei fullHD bleiben. die engines werden geiler, ja, aber wohl kaum so ein riesen grafikunterschied.
schaut euch doch mal die letzten 5 jahre als beispiel an. da hat sich bei den fullHD fernsehern auch nicht soooviel getan. LED kam dazu und hatte ein bunteres, helleres und etwas schärferes bild. das wars auch. ich habe im büro einen alten 40 zoll samsung von 2008 rumstehen und das bild in fullHD ist auch heute noch top. im wohnzimmer dagegen einen aktuelleren 3d 55 zoll led samsung. klar, bild ist durch die oben genannten punke etwas schicker und kräftiger, aber keine weltbewegende sache.
ich denke uns werden (dank der starken hardware) eher die neuesten spiele engines flashen und komplett neues feeling verschaffen als die grafik an sich (sprich fotorealistisch zB.) für die xbox 720 erhoffe ich mir mindestens ne grafikkarte ala geforce gtx 680 oder höher. alles andere wäre eine enttäuschung.
Aber wie gesagt, für Filme muss 4K schon fast rein wenn man den Lebenszyklus lange halten will. Die Konsolen sind ja schon lange nicht mehr nur zum spielen da.
Völliger Quatsch, selbst wenn nicht werden Filme dadurch nicht weniger oft geschaut oder Filme selbst werden dadurch nicht schlechter. Filme wurden durch 3D auch nicht besser.![]()
Also sollte die Industrie nie wieder den TV verbessern ?
Wenn die Technik da ist dann sollte man auch diese umsetzen. Oder willst du wieder zurück zu 50Kg TVs und VHS ?
Und was war mit dem BlueRay bei der PS3???
Bei PS3 Launch hat eineinzelner Player deutlich mehr gekoster als ne komplette PS3....
Du kannst das alles nicht vergleichen....
Ausserdem denk ich mal das solche Entwickler mehr Ahnung bei dem Thema haben als du![]()
5 Besucher
