Iist gerade xbox live und xbox.com down?
bei mir steht 0 Freund online und freunde kann ich auch nicht aufrufen
Wichtiger für mich wären Dolby True HD und DTS HD Master....ja kollege sagte das nun dobly digital in der liste zur Auswahl mit steht
mal sehn ob er mir nen bild schickt zum bestätigen![]()
Meine auch irgendwo gehört zu haben, dass mit dem Update die geheimknisvollen Reserve-Kräfte der Box freigeschaltet werden und diese dann zu ungeahnten Höchstleistungen antreibt.
Xbox One March Update Brings Dolby and Bitstream Audio Support
Feb 26, 2014 by Josh Pollard
Many made a big deal out of the Xbox One’s lack of Dolby Digital support when the console launched in November. It was an easy way to criticize the console for not living up to true next-gen standards. Those who were looking to point out these deficiencies just ignored the fact that most people would be hooking up the console to a TV (which probably doesn’t have surround sound at all) or an audio receiver that supports DTS Surround Sound (which the Xbox One supported at launch). There was one group of people who had a valid complaint though. That group would be users of certain surround sound headsets. The Astro A50 headset is a very popular wireless surround sound headset that only supports Dolby Digital. Microsoft has revealed many details about the multiplayer enhancements coming in the March update to the console, but while using the preview of the update we’ve found another enhancement worth mentioning. This will be the update that brings Dolby Digital audio to the Xbox One.
Previously the audio settings on Xbox One gave you two areas to adjust: HDMI and optical audio options. Under HDMI you had the ability to select stereo uncompressed, 5.1 uncompressed, 7.1 uncompressed, and DTS Digital Surround. If using optical audio you were only presented with stereo uncompressed and 5.1 uncompressed. With the new update “Bitstream out” is added to the HDMI audio settings. The optical audio settings are changed to only offer stereo uncompressed and Bitstream out. They’ve then added a third setting for modifying the bitstream format. In that menu you can select DTS Digital Surround or Dolby Digital. We tested these options with optical audio and our audio receiver responded to both correctly. You can see photos of the update interface in the gallery below.
While we weren’t expecting the audio settings to be improved with the March update, we’re sure some of you will be quite happy to see these new options. We expect this system update to be released within the next week, so you won’t need to wait much longer to configure them exactly how you would prefer.
Jetzt mal rein praktisch gesehen: macht es denn von der Bildqualität und evtl Eingabeverzögerung einen Unterschied, ob ich die X1 per HDMI direkt an den TV anschließe oder an an den AV-Receiver?
Im Moment habe ich letzters, sonst hab ich nur Stereo. Aber nach dem Update könnte man ja per optischem Kabel an den Receiver gehen, wenn es denn einen unterscheid machen sollte...
). Ich weiß jetzt nicht, wie gut der "durchschleift"
Mir ist zumindest keine merkliche Eingabeverzögerung aufgefallen.
System Update März 2014 löst 50Hz TV-Problem, erste Bilder zum neuen Feature
Mit dem Xbox One System Update März 2014 werden zahlreiche Verbesserungen veröffentlicht. Dazu wird endlich das 50Hz Problem beim Fernsehgucken beseitigt. Durch das HDMI-Passthrough kam es immer wieder zu leichten Rucklern, da die Xbox One versucht den Input mit einem 60Hz Signal durchzuschleifen.
Sobald ihr das März Update auf eurer Xbox One installiert habt, könnt ihr im OneGuide die 50Hz Option aktivieren. Wir haben dieses Feature bereits ausprobiert und können bestätigen, dass danach das TV-Bild besser aussieht und bei schnellen Bewegungen nicht mehr ruckelt.
Quelle:http://www.xboxdynasty.de/Xbox-One-Dashb…news,37286.html
