Quelle: http://www.extremetech.com/computing/115…your-smartphone
Can I blow up my USB device?
There
is a huge variance, then, between normal USB 2.0 ports rated at 500mA
and dedicated charging ports which range all the way up to 2100mA. This
leads to a rather important question: If you take a smartphone which
came with a 900mA wall charger, and plug it into a 2100mA iPad charger,
will it blow up?
In short, no: You can plug any USB device into
any USB cable and into any USB port, and nothing will blow up — and in
fact, using a more powerful charger should speed up battery charging.
The longer answer is that the age
of your device plays an important role, dictating both how fast it can
be charged, and whether it can be charged using a wall charger at all.
In 2007, the USB Implementers Forum released the Battery Charging
Specification, which standardized faster ways of charging USB devices,
either by pumping more amps through your PC’s USB ports, or by using a
wall charger. Shortly thereafter, USB devices that implemented this spec
started to arrive.
If you have a modern USB device — really,
almost any smartphone, tablet, e-book reader, or camera — you should be
able to plug into a high-amperage USB port and enjoy faster charging. If
you have an older device, however, it probably won’t work with USB
ports that employ the Battery Charging Specification; it might only work
with old school, original (500mA) USB 1.0 and 2.0 PC ports. In some
(older) cases, USB devices can only be charged by computers with
specific drivers installed.
ich verwende derzeit diese Eneloops. Jetzt halt die Frage, was passiert wenn ich das Handyladekabel anstecke?
Fall 1: Akku/Controller schmort durch
Fall 2: Man kann zocken, Akku lädt nicht
Fall 3: Mann kann zocken, Akku lädt
Laden weiß ich nicht, da ich noch kein Akku hab XD Aber der Controller kann mit dem Handy-Stromkabel (Also für Steckdose nicht ust am Ende) betrieben werden. Das hab ich getestet... Batterien raus und Kabel ran klappt ohne Probleme. Daher nehme ich an, wenn die Akkus einen Mini-USB Eingang haben sollten sie damit laden.
Denke gerade über:
http://www.amazon.de/Venom-Twin-Recharge…+one+akku+venom
nach... alternative zm Original mit 2 Akkus...
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »orderbaron« (29. April 2014, 17:21)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Bravo SX« (30. April 2014, 14:25)
23 Besucher
