Das mit Second Assault versteh ich grad nicht.....
We’ve started rolling out a new Battlefield 4 game update on Xbox One.
You may experience some downtime during this rollout, as we are also
updating the game servers. As usual, it will take a few hours before the
majority of servers are updated.
This update is mainly designed to prepare the game for the upcoming
release of the expansion pack Battlefield 4 Second Assault. We will
announce the release date for this expansion pack later.
Jan 30 Xbox One Game Update Notes
DMR Balance Tweaks
- Increased the damage of all DMRs across all ranges. Specifically,
damage has been increased at long ranges to allow three-hit kills
against unarmored opponents. Additionally, reduced the penalty to
accuracy for sustained DMR fire, allowing more rapid follow up shots in
combat. The amount of the damage increase varies from weapon to weapon,
according to its intended range, rate of fire, and damage. We will
continue to monitor the effectiveness of DMRs in combat, and determine
if additional action is needed to make DMRs a viable mid to long range
weapon.
Other items
-Greatly reduced the risk of crosshairs disappearing, which would also result in hit markers disappearing
-Added a headshot icon on the killcard. This should help identify instances where players are correctly killed by one shot
-Fixed an issue in Squad Deathmatch where the “Win/Lose” text was overlapping
-Fixed an issue with players using an exploit for the SOFLAM
-Fixed an issue with players using an exploit for the MAV
-Fixed the gameplay code to properly track the FOV (Field of View) changes in the options menu
-Fixed an issue where chat would break when entering "false" or "true" in the chat window
-Fixed an out-of-helicopter glitch in Air Superiority where players could spawn on the ground and play as infantry
-Fixed the misaligned crosshairs on the T90 MBT
-Added setting to tweak joystick dead zone
-Various minor crash fixes
http://battlelog.battlefield.com/bf4/for…64773335000081/
Kann mir das mit Second Assault mal wer erklären ? Das gibts doch schon lange....![]()
Ja, ist 1:1 kopiert. Echt schwach. Oder gibt es auf Konsole ein Chatfenster?Als ob die das von den PC/PS4 notes kopiert hätten.....für one gibts ja schon sa
Also irgendwie habe ich den Eindruck als behandel man die Konsolen "stiefmüttlerich". Alleine dass der Serverbrowser noch immer nicht korrekt funktioniert ist schwach. Das sollte nun wirklich nicht das grosse Problem sein dass zu beheben. Auch dass sie die DMR´s noch stärker machen obwohl ihr davon berichtet habt dass die eh schon zu stark sind / zuviel genutzt werden muss man nicht verstehen-Fixed the gameplay code to properly track the FOV (Field of View) changes in the options menu
.Ehm ja irgendwie habe ich wirklich ein Chatfenster welches man sieht wenn man mit "RB gedrückt halten" einen Befehl gibt.Ja, ist 1:1 kopiert. Echt schwach. Oder gibt es auf Konsole ein Chatfenster?Als ob die das von den PC/PS4 notes kopiert hätten.....für one gibts ja schon sa
Habe echt den Eindruck als habe man bei Dice keine Ahnung was auf Konsole Stand der Dinge ist.
6 Besucher
