Infos vom Live Stream:
-1080p, 60 FPS, 64 players confirmed for XB1 and PS4
-5 players per squad
-4 classes (Assault, Engineer, Support, Recon)
-In-game VOIP confirmed
"Levolution"
-Every map will have changes that can alter the makeup of the map/level.
-Also refers to the verticality they want to add to maps.
-So far, not scripted--can take out supports to bring down skyscraper
Commander mode
-One player on each side that does not occupy a player slot (64 players + 2 commanders)
-Can be played from console, PC, or remotely with a tablet
-Scan and EMP UAVs can be deployed; vehicle scans, tomahawk missiles, infantry scans, and gunships can be deployed based on whether or not certain bases are capture
-Supply and vehicle drops
-Set attack orders for individual squads
Vehicles
-Enhanced vehicle disabling: Vehicles are disabled based on the parts that are hit (e.g., tires can be shot out)
-Limited MBT ammo
Other/mechanics
-Squad assists can count as kills if you contibuted the most to the kill (maybe >90%?)
-Reduced suppression: Support now contributes the most to suppression and it has a greater effect at long range
-ADS near cover allows a "peak" cover system. Not sure if you can lean left/right, but seems you can pop up above cover
-"Click to spawn" deployment options
-Interface is muuuch less click-heavy vs BF3
-Movement system has been tweaked for momentum; it takes a moment to get to full sprint speed
Swimming
-Can dive to avoid gunfire
-Can shoot pistols under/above water while swimming
-Can sprint swim
Spectator mode
-Confirmed for PC, "we'll see" for console
-Views: Table Top, First Person, Third Person, Free Cam
-Can "set" up to four free cams around the map to quickly jump to certain location
-UI can be turned off
-Can click on player from table top view and get PiP view of their screen
Class info
-Assault has standard medpack, and a "small" medpack, which you "stick" to someone. It regenerates their health, regardless of their proximity to you; defibs need to be --charged before you can pick someone up
-Recon has C4 and motion sensor ball
-Improved environments
-Metal detectors can expose you, storefront gates can be shut to cut people off, fire extinguishers create smoke screens, bollards can prevent vehicle access
-Water reacts dynamically to vehicles and events (skyscraper falling)
Weapons/equipment
-Flashbangs are in
-Pistols can be customized
-Tons of attachments/customizations (green hipfire laser sights, different foregrips, barrel types, bipods, silencer/flashlight combo)
http://67.227.255.239/forum/showpost.php…1&postcount=160
