Vega1987
  • »Vega1987« ist der Autor dieses Themas
Beruf: Beikoch
  • Vega1987
Sonntag, 3. Mai 2009, 15:03
Puzzle Erfolge
Ich brauch die letzten beiden puzzle 4-5 hat einer ein ahnung wie die gehen wäre echt gut wenn das jemand weiss
MFG.:Vega1987 :D
Sonntag, 3. Mai 2009, 16:10
Hier mal eine Anleitung auf Englisch was zu tun ist für die beiden Puzzle Erfolge 4 + 5:
01 Yee Haw10 Puzzle #4
Challenge Pack - Free
The
achievement an only be obtained using the Dodge Challenger (well this
achievement is based on the Dukes of Hazard). Just start a race on St.
Petersburg, The Hermitage Race in reverse using the Dodge Challenger.
Drive forward some distance and then turn around and floor it. Jump off
the bump in the road at the start of the race and lean the car slightly
forward and land back on the road. You need about 130 MPH or more to
make the jump. When you land the achievement should unlock.
Are You the One?10 Puzzle #5
The achievement can only be obtained using a Ducati 998 (The achievement is
based on The Matrix when Neo jumps off the lorry on the motorway with a
998). To get the achievement just start up a race on St. Petersburg,
The Hermitage Race in reverse and use a Ducati 998 and make sure you're
in an external view. You will see a bump in the road when you start
which you will air off and do a 360 camera rotation clockwise. I
recommend setting the camera to the and then holding the right as you go off the jump.
Es ist wie es ist!
