Entweder es ist ein Mass Effect Shooter like Mass Effect Reach. Also ein Mass Effect Shooter der während den turianischen-mensch Krieg spielt(Erstkontaktkrieg?)
Oder ein neuer Teil von einem frühreren BioWare Franchise "Shattered Steel"? Ich zitiere einfach ganz schnell 360A.org, wie ich dort draufgekommen bin:
It only surfaced a little while ago, but already we're getting the distinct impression that this could run and run. The mystery behind BioWare's teased major new project has just taken a slightly bizarre twist, as the developer has tweeted a pair of barcodes that games blog Rock, Paper, Shotgun have had a good go at decoding.
Apparently, barcode number one when scanned reveals a stream of binary numbers that when decoded leaves the number 55.845, which is the atomic weight of iron. Iron of course makes steel, which might suggest that BioWare could be ressurecting it's 1996 mech shooter, 'Shattered Steel'.
The second barcode meanwhile, reveals the number 128.5, which as you'll well know, is the lowest recorded temperature on planet Earth, in Vostok, Antarctica. The Mass Effect fans amongst you will instantly recognise that there's a system in the first game called Vostok, so there's certainly a case for something Mass Effect-related there. Vostok 1 was also the first manned space flight 20 years ago. But then again, it's also a temperature low enough to shatter steel... we'd imagine.
Of course, this could all be torturous teasing on BioWare's part, but all will be revealed soon enough... We hope.
http://www.xbox360achievements.org/news/…ed-Steel-?.html
